Rescu2000
I've read that extra lighting added to the existing interior lighting can burn out the BCM. I assume that this is due to the BCM controlling the lighting for the "dim to off" feature, auto shut off if left on, etc.
I would like to add the stock light pod that I removed when I added my EVIC to the rear passenger area. I'd also like for it to be tied into the BCM's dimming features and be controlled by the doors, etc but I don't want to chance burning up the BCM.
Here's my question: Has anyone thought of using an Base, collector, emitter transistor to boost the current in this circuit? Wouldn't this take the strain off of the BCM? I was thinking I'd put this in the front light pod so that even the front lights are boosted, thus lowering the total load on the BCM to (probably) below stock. This should theoretically work and still allow for the gradual dimming of ALL the lights, and I imagine you could add more lights in the back if you wanted...
Anyone more fluent in electronics care to help with this?
Thanks,
Rescu2000
Thanks,
Rescu2000
