Engine rattle
Tog
AU
I agree and it may just be coincidence and not the cause
Sent from my SM-G930F using Tapatalk
Logan Savage
WV
Somethings not adding up . Only a pint low but no oil showing on the dipstick .
Tog
AU
My bad should be 2 pints put wrong info in the the converter
Tog
AU
Looked at the mark on the oil bottle there was about 1 litre maybe a little more which my volume converter app says is about 2.1 pints
Logan Savage
WV
Are you saying that app. 1 quart took it from no oil showing on the dipstick to full ?
teeje
Toledo
Timing chain kit guaranteed. Had this problem before i got my new engine. Wretched for 5 seconds. Brought back terrible memories
If its been going away when warm, thats the tensioners getting oil pressure. They're bleeding out when shut down
Sent from my SM-N930P using Tapatalk
Tog
AU
Its quiet when cold and rattles when hot. Rattle doesn't go away with the sepentine belt removed
teeje
Toledo
Hm, tensioners are all kattywampus then.
JeepinJarhead03
Petersburg VA
sounds quite similar to other 3.7s when rev'ed that had failed timing chain hydrollic tensioners and the tensioner arms were slapping.. but
they did it both cold and warm
, if it was mine, due to the recent loss of oil and such, id change the oil and disect the oil filter and be looking in the oil for metal particulate , then pull the valve covers , then the timing chain cover etc in that progression until i found what the issue was
Tog
AU
Thats sort of the plan i was going to follow i may even drop the sump and check all things from the bottom
Tog
AU
How hard is it to get to the timing cover I have never looked at it
Remove the water pump then there are 16 bolts around the outside (various lengths though the same bolt size - keep track of where they go.) You'll need to remove the tensioner pulley, power steering pump and a few other goodies but pretty straightforward process.
Hope all goes well for you and it's a simple fix :waytogo:
Tog
AU
Cheers twobob so do I
teeje
Toledo
Keeping everything in time is the hard part.. if you're going to be in there, replace the guides all tensioners sprockets and chains.
Tog
AU
So I pulled the oil filter and drained the sump no particulates in the filter or the sump oil. Refilled with a thicker oil 15w50 and while the rattle is not gone when hot its not as bad anf the really bad rattle when revved is gone both revving up and when revs die which definitely points to the possible hydraulic tensioners failing. Also picked up a stethoscope while at the parts shop the only place you hear the rattle well is on the sump or i think its the bottom of the timing cover from underneath.
teeje
Toledo
Its definitely timing component related. Be ready for that.
Tog
AU
Yep going to a mechanic I dont have the time to do it myself and im over spending my spare time under the jeep
