Difference between water pump and freeze plug leak diagnosis?
YoungL
Oregon
I think i have an issue with my jeep leaking a small amount of coolant under the center right side of engine compartment. I was wondering if anyone could tell me a quick giveaway for a freeze plug leak vs a water pump? Thank you
CactusJacked
Chicago Suburbs
Yeah, you get under there and see where the trail of coolant is originating from. Wipe it dry if you can't tell, then run the engine while watching for a drip.
By the way, engine blocks don't have freeze plugs, they have sand casting core plugs. ;)
YoungL
Oregon
Lol i have no idea. Do you know if a sand cast plug leak is a serious repair? The leak is coming from the right side of engine and is dripping slow (some days not at all) down to the oil filter drain guide and then dripping off of that...the water pump looks ok on the top ... But everyone s
ays waterpump...
CactusJacked
Chicago Suburbs
The plug is cheap, labor isn't. Not a serious repair, but how long it takes depends on how accessible it is. You need to trace the water trail further up. A mirror can help you see around obstacles if there's too much crap in the way.
streetglideok
Colorado Springs
Technically you are right, the plugs are for the sand in the castings, however if you go to the parts store and ask for a sand casting plug, they will look at you like you're on some kind of crack. Just call them a freeze plug which is what they are known as to the parts guy.
CactusJacked
Chicago Suburbs
Don't give in to the counter experts, they may thank you some day. I like to leave them baffled for a moment as they drool and stare aimlessly in their misguided notions.
"Eradicating automotive illiteracy one person at a time". ;)
Well, gotta run to the parts scholar store. I need to get me some new break calibers and freon!
02redKJ
Coos Bay Oregon
Have you pulled the belt off to see if there is any lateral movement yet? This is a 5 minute test. I highly suggest this before moving on with a whole bunch of what ifs... My guess is that your gasket has a leak at the bottom right side of the water pump. I could not find where my leak was coming from either until I pulled the water pump. The pump was fine, it was only the gasket. I would just buy the gasket and then remove the pump. Then if it is the pump, you take the gasket back and buy the pump. I didn't do this. I bought the pump, only to find it was just the gasket. If it isn't the gasket, then you are only out a little bit of money, like 8 to 10 dollars instead of 55.00 for the pump.
YoungL
Oregon
No... i have a day off on tuesday and im going to go for it then. I appreciate the help. I figure if I have to take the whole thing off i might as well just replace the pump and save myself the trouble down the road... i have about 103,000 miles on the jeep. I can't afford any other repairs it's been a bad month so im hoping it is the pump. Thanks for the help
frontrangecctv
Denver
If you are going to replace the water pump, it might be a good idea and spend an extra $7 and replace the thermostat ($18 for a fail-safe t stat) while your down there. I actually had this same issue you had with my 06 Liberty. Coolant was leaking and dripping into the oil filter drain chute. It was coming from the bottom of the water pump. It appeared it was just a bad gasket, but I went ahead and replaced the pump and thermostat. At 103k miles, if you already haven't done so, it would be a good time to drain or flush coolant system too.
YoungL
Oregon
I finally found the leak...its at the bottom of the waterpump. I believe its just the seal so i think ill go ahead and replace the pump as well...cant afford dealer pump, is that what you used? its kind of a bummer because i had the coolant flushed at 92,000 miles! Thanls for the help!!
Napa/Carquest if not using OEM.Stay far away from advance auto parts,autozone,and O'Reilly's for hard engine parts.
