SDLiberty
What is the differance between CRD front coils and the 3.7 gasser coils? Longer, coil spring dia/ stiffer? Looking at installing them with my 2.5 Daystar lift. Pros vs Cons.. any help will do! Thanks
durango rears are decent i hear and cheap
?????????????rear springs....you use Durango rear shocks if you are lifted not springs
So get it re-aligned will not help this at all??? Was really hopping they were longer than that. The metal part of the brake line on the caliper side is really what kills me. If the rubber was longer and metal was shorter... I'd be in like flin! Got any UCA around you wanna sell for cheep.You need JBA's UCA's now to help with that problem,maybe.Or you need to cut down that spacer by at least 1" to get back at a lift that will not kill your brake lines.The extended brakes lines will not help you at all,actually the extended front lines are really only about 1/2" longer,maybe,but the OEM lines are more then long enough.You will crush either brake line sooner or later.
Keep the thoughts coming!!! Thanks!!!
I thought i might add that the pics of spindle and UBJ are taken with out a jack or stands under it....
looking at my daystar kit i see that you can route the brake line under the ball joint. obviously you would have to cut off that whole bump stop but hey my daystar kit dosnt have it. did you get new crd coils or used ones?
So what was wrong with the CRD coils in your gasser? just rode stiff or was it damaging. if it was just stiff ill buy those coils from you. your front end looked real nice! here's my saggy front end ha:
