Clicking from Rear around Turns
dude1116
Pompton Plains, NJ
Hey guys!
Been getting a clicking when going around turns (left turns more than right) from the rear. Sounds like it's coming from the rear passenger side. Does anyone have any ideas of what it can be? Could it be a hub?
Been spinning the hub by hand with the wheel off and it does make a slight clicking but I think it's just the teeth of the gears engaging.
Only problem is, the hub has no play and does not make a howling noise. Brake shoes are on good and are not interfering.
Very confused on this one.
Thank you!!
rjkj2005
US
It's your cv joints on your axels. Time for new ones
Sent from my SM-G900V using Tapatalk
dude1116
Pompton Plains, NJ
CV joints in the rear ?
Are you sure its from the rear, sounds can travel at times
do you have a open diff on yours?
Yeah definitely from the rear. Believe it or not I thought it was the front originally. Replaced the CV axle and half shaft on the passenger side and the clicking was still there. Couple of mech friends were sitting in the back and told me it was coming from the back for sure.
I have an open diff.
I'm thinking it has to be a wheel bearing. I'll probably replace the hub soon enough.
