2003 KJ - fail of 4wd for a short time.
JustSumDad
Vancouver Island B.C. Canada
So today I was driveing on wet pavement on the hwy and thus in 2wd, I turned off onto a packed down snow road and on the fly but at slow ish speed I selected PT4wd and proceeded.
As I started up an incline on the road, it started to spin, rear only... confused I slowed, had to anyhow... clicked back and forth from 2wd to 4wd and it was clearly stuck in 2wd only...
I also tried FT4wd and no luck, brakes on full stop, nothing only 2wd. I gave up, put it in park, tried 4 low and then had front dig.. Stopped, went back to 4hi (sorry FT4wd) and finally had it working...
The lights on the dash were showing what I expected, everything felt like it was getting selected correctly, I did not feel play in between the clicks...
I always thought the libby had a live axel... Was I exprienceing an auto hub locking issue?
Any ideas?
JustSumDad
After exploreing a bit, it seems the Libby does NOT have any form of hub disconnect...
So hopefully someone can tell me why I was not abel to get front dig until I went all the way to 4 low...
Mine sometimes needs a nudge of reverse to get it to drop into 4x4, probably a bit sticky from lack of use.
JustSumDad
thats really weird to me, but I dont actually know how the tcase is setup... I thought the lever ran a cable direct to the tcase shifter arm and that arm was directly connected to the shift fork... so it if the lever moves it has to engage...
is it maybe spring loaded somewhere in between?
24turbo
Alberta Canada
When you pull the transfer case lever it doesn't necessarily fully lock into 4wd immediately. There are synchronizers that need to mesh together to fully engage 4wd. The synchronizer on one side is spring loaded and it is a slight difference in front vs back wheel speeds that allows the synchronizers to rotate enough to "lock into each other". If they meet directly against each other it may take a bit to get them rotated enough to get the meshing required to engage 4wd. This is to allow "on the fly" shifting into 4wd.
The indicator light is only an indication of the linkage position, not a confirmation it is actually fully functioning 4wd.
JustSumDad
ok, this is makeing some sense, tho it was quite a bit of messing about to get it to lock in...
I was on an icy hill, brakes on no wheel spin, went from 2wd to 4pt and released the brake, rear spin only, brake on, wait a sec, slight gas-still 2wd only. Did the same in 4ft, did all this over and over while switching between nutral and drive. Finally I put it in park and went to 4low. This was when it finally got front grab...
My old Zuki did none of this messing about, if you felt the lever move you got what you were in, if the gears did not line up, the lever would not move.
Actarus-Euphor
Aren't there also disengageable hubs on the front wheels that could also have been late to engage?
(I had more or less the same situation once)
ikuo78
Japan
Maybe the rear wheels were spinning a little when you shifted to part-time.
Sometimes, even if I shift to part-time to lock the front wheels during maintenance, they won't turn on.
Even in such a case, if I move the car enough to turn the tires half a turn, it will turn on.
When I want to get 4WD while driving I usually shift up to full time when coasting.
It seems difficult to switch to 4WD when stopped on an icy slope.
It's scary to go backwards, but if you go backwards for about one rotation of the tires, you might be able to turn on.
I didn't notice it because I always put it into 4WD early.
Thank you for sharing your instructive experiences.
There was a note in the instruction manual regarding such situations.
DadOSix
Cumberland, MD.
Also - please be aware that just because the dash lite says you are in 4, or part time, does not necessarily mean it is so.
The transfer case switch gets ‘gummy’ and the indicator is not accurate. A new mopar switch will solve this, if that is what it is. The person I got my 06 from, also thought the 4wd was failing as it did not pull 4 when the lite said so. A little gravel road and some finess on the 4x4 selector handle was enough to show it was working, but the indicator still said nope.
towpro
SE pa
probably not the same, but mine was doing this with 80K miles for the previous owners so they traded it in on new jeep. I bought it off the "wholesale" lot before the auction guy showed up. Turned out the switch on top of transfer case was shot and it was showing showing 4wheel part time even in 2wd. but shift to full time 4 wheel or low it would change. put in new switch (from top) and problem went away. and I used the cheapest aftermarket switch I could find.
24turbo
Alberta Canada
I cant say for sure why your engagement is so slow, but my best guess is maybe your synchro is damaged or the spring is weak or broken. Hard to know the history.
I havent had a transfer case apart for at least 5-6 years so Im going by memory here. Unfortunately it will cost a fair amount to find out as it seems when you mention major powertrain components the shop instantly sees dollar signs. Removing and pulling apart a transfer case isnt particularly hard but seems to demand good cash
CheddarGau
Lower Mainland BC
My nieces is the opposite, it says always on. I told her to just look at the level and not worry about it lol
