Powerslave
Well, I under went the chore of replacing the spark plugs...
All in all, was fine, just had to remove the intake tube...
I used Bosch Platinum +2s, like I did in my Avenger. Runs nice.
This is kind of nice, the Coil-Plugs, because with little modification, you can replace them with individual Blaster coils, and regular plug wires, with long boots. I dread the cost of a factory replacements, so, hooking up a modified system won't be hard, from what I see. There is plenty room to mount six coils, or thee dual coil setups. The signal and supply wires only need routed to the coil packs... Replacing just ONE if ONE goes bad? Just have to make sure the individual coil delivers the same spark power as the factory plug-coil. Need specs on that, anyone know the spark voltage?
