streetsnake
- Joined
- Jan 22, 2022
- Messages
- 99
- Reaction score
- 30
@tommudd Sorry to bug you on this but is my list accurate? Anything else I should get while I’m at it? Thx. BenGotcha. Is the rest of my list good?
You can use either the OME 132Ls or the bilsteinHi guys. I think I have it. Please take a look below to confirm and provide any thoughts/guideance. PLEASE
So...I need these:
The shocks directly below say they are not for a 2010 application but they are, correct?
Old Man Emu Nitrocharger Shock Absorber (N132L)
Nitrocharger Shock Absorber (N132L)www.offroadwarehouse.com
or I can get these instead of the directly above, correct?
a set of these
2002-2013 Liberty KJ KK Nitro Front Bump Stop Extension Bushing Fr 2-4" Lift Kit | eBay
Jeep Liberty 2002-2013 KJ KK. The extension bushing ensures correct bump stop clearance and prevent suspension from bottoming out for Jeep vehicle. It's for 2-4" lift kit. Dodge Nitro 2007-2012. Bump Stop Extension Bushings x2.www.ebay.com
A total of 12 Hockey pucks. Is there an aftermarket bump stop that I can get instead of hockey pucks? Anyone have a pick of what this looks like and how they bold together?
And a set of these:
JBA Upper Control Arms for lifted Jeep Liberty's 2008-2012 , Dodge Nitro 2007-2012
The JBA Value Pack JBA Max 90 Ball Joints™ Patented JBA EZ Lube Bushings™ JBA Lifetime Warranty JBA 365-day Return Policy JBA Installation Book JBA Stickers JBA Upper Control Arms are preassembled and ready to bolt into your Jeep Liberty and Dodge Nitro! American-made steel tubing, red...jbaoffroad.com
What else while I'm at it replacing the suspension of my KK?
Oh ****, I’m just looking at my list. I’m missing shocks for the front. Which OME or Bilseins do I get for the front. Should get the tera flex stops for the front or are the ones above okay? Sorry. I thought I had it correct?You can use either the OME 132Ls or the bilstein
everything else looks good
Yes those will work !Oh ****, I’m just looking at my list. I’m missing shocks for the front. Which OME or Bilseins do I get for the front. Should get the tera flex stops for the front or are the ones above okay? Sorry. I thought I had it correct?
these are what I need?
Bilstein B6 4600 - Suspension Shock Absorber (24-139168)
B6 4600 - Suspension Shock Absorber (24-139168)www.offroadwarehouse.com
You can replace the front bushings for the sway barI got all the goodies ordered. Just wish it was a bit warmer. LOL Should the front and rear sway bars be changed as well? I didn't know if these are an upgrade or if it is more of a bushing condition question.
Jeep Liberty Dodge Nitro Front & Rear 4 Piece Sway Bar Link Set TRQ PSA55982
Order your 4 Piece Sway Bar Link Set - today at 1AAuto.com. Up To 50% Off Prices EveryDay! Get Fast & Free Shipping On Premium Quality Parts. Shop Now & Save!www.1aauto.com
Doesn't seem like it has been that long , or wait maybe it does ! LOLDang, that was 8 years ago?! Wow.
It’s a pain. I spent more hours than I care to admit cross referencing part numbers and searching for who had what in stock. Many sites show they have them, but don’t. Off-road warehouse was my choice after I called them and they didn’t lie- they explained these parts were direct from manufacturer in Australia, and would have really long lead times.Ok. ill See if I can finally figure this out tomorrow. Ugh
Two each side. Howies Hockey Tape will sell you four for two bucks a pop. You’ll need a pair of long carriage bolts, carriage bolt washers, and some by lock nuts from your local hardware store too. I bought six inch long bolts and trimmed them to length.For the hockey pucks being used as bump stops on the rear springs, utilizing the above-mentioned springs, how many hockey pucks on the bottom? Do the bolts need to be counter-sunk? Also, do I utilize pucks for the top bump stops? If so, how many and how are they mounted? Thanks for the help.
I got 12 pucks. I was going off your list. I thought I read it right. You have 4 on the bottom of each spring and 2 on the top? That seems like too many? So you bolt the top ones the same as you do the bottom?Two each side. Howies Hockey Tape will sell you four for two bucks a pop. You’ll need a pair of long carriage bolts, carriage bolt washers, and some by lock nuts from your local hardware store too. I bought six inch long bolts and trimmed them to length.
If using stock width wheels then 2 per sideFor the hockey pucks being used as bump stops on the rear springs, utilizing the above-mentioned springs, how many hockey pucks on the bottom? Do the bolts need to be counter-sunk? Also, do I utilize pucks for the top bump stops? If so, how many and how are they mounted? Thanks for the help.
Stock bump stop on the top. 2 pucks each side on the bottom.I got 12 pucks. I was going off your list. I thought I read it right. You have 4 on the bottom of each spring and 2 on the top? That seems like too many? So you bolt the top ones the same as you do the bottom?
I hooked up a garage heater today. My garage will be warm for all the fun. So all the springs/shocks will take awhile to arrive? That stinks.
