I’m really ANGRY with OME = trash
Hi everyone!!
I’m from Mexico, maybe some of you have seen one of my YouTube videos (Mi Jeep es una Dragona)
I’ve had RC old 3” lift kit (the one with aluminum spacers), Bilstein shocks and JBA UCAs from around 3 years ago and finally in August of this year decided to take RC apart and get a pair of expensive OME 927
Well, as I’m in Mexico the only way to get this stuff is importing it from USA, the OMEs cost me $262 shipped to Laredo and after customs and Mexican taxes, I payed around $340
I was very happy, so as soon as I got the springs, I installed them into my Jeep, the final size from bottom border fender flare to the center of the wheel was 21”
That was a bit disappointing, but said “well, at least runs a lot better than before, it’s softer and more comfortable”
Also, bought a couple of clevis from KK (haven’t installed yet) and some conduit nuts to use them as an spacer to achieve at least 22” (I’m running Cooper STT Pro 31”)
But the worse has yet to come!!! Because today, less than 2 months since I installed OME 927, the springs have sagged and now I only have 1” of lift (total size 20”)
My tires are rubbing in each bump, or when I turn the steering to any side.
I’m really upset with this trash of OME, because I spent a lot of money, while I just could have bought a new set of RC 3” lift kit (the KK fits the KJ) as the one I’ve installed to a customer two weeks ago. His Jeep is taller than mine, and the front shocks with struts are around the same cost as OME 927 ‍♂️
As I’m in Mexico, it’s impossible to me claim warranty or something like that because the shipping costs to USA maybe will be as much as the parts.
Tomorrow I will try to install my old RC aluminum spacers or at least the KK clevis and the conduit nuts.
Any ideas are appreciated.
duderz7
Weiser, ID
That's unfortunate, I'm also running 927s and have been for years like many others here and my kj sits nice and tall still. I wonder if you got 925s in a 927 box? Any tags on the springs?
RenKJ
Canada
I'm pretty shocked, running OME for about a decade and haven't noticed sag
WWDiesel
Central Georgia
I'm running IronMan 4x4 Springs with 1/2" clevis spacers; no sag that I can tell with ten years of use.
gvaldez
San Diego, CA
Is there no path here for warranty? It seems like you were sent either a bad copy of 927s or something different. Have you tried contacting supplier and or manufacture direct and see if they can pick up the shipping.
ratrod0
I watch your videos, I'm sorry that this is happening to you. Best of luck.
nbas
Greece
I am sorry for that! I have the 927 for 9 years with no issues
Right off the bat, those springs were sitting low and sagging from the start. Well not really. I think it your set-up...
Here is my understanding how the hub-to-flare math works on a Liberty:
  • Stock new springs: ~19 inches
  • 2-inch lift: ~21 inches
  • 2.5-inch lift (where OME 927s should land): ~21.5 inches
  • 3-inch lift: ~22 inches
  • 4-inch lift: ~23 inches
Since you measured 21 inches right after installation, you only got 2 inches instead of the standard 2.25 to 2.5 inches. Dropping down to 20 inches now means you only have 1 inch of actual lift over stock.
Do you have an ARB front bumper or a winch on the front end? I watched a couple of your YouTube videos and one shows an ARB bumper with a winch, while another shows just a winch setup.
Adding that extra weight to the front end completely changes things. OME 927s are only designed for light/medium loads (a stock front end without heavy accessories). If you're running an ARB bumper and winch, that extra 150+ pounds will crush 927s and make them sag right away. To support a bumper and winch, you need heavy-duty springs like OME 790s or 928s.
If you don't want to buy new springs, the 927s themselves aren't bad—I think you just overloaded them. You can regain your height by adding a clevis spacer, some conduit rings, and a top plate spacer to compensate for the heavy front end and get your stance back where it needs to be.
James Akemon
He's not the only one with crap 927 springs. I sit at 20 1/4 with a 1/4 leveling spacer. So that means my 927s have given me 3/4 inch of lift. No winch, no steel bumper
Front-end weight absolutely matters—basic physics dictates that hanging 150–200 lbs of steel bumper and winch off the nose completely changes spring compression. OME explicitly rates 927s for standard stock front loads, which is why 790s exist for heavy front ends.
This isn't a new debate either—this exact issue was settled on the forums years ago. In an old thread on this exact topic, TomMudd explicitly stated: "IF you have an aftermarket bumper and winch then 790s." Another member (sydbro) running an ARB bumper and Warn winch on 927s reported major sag, barely breaking stock height after under 1,500 miles because he ran 927s instead of 790s.
There are plenty of people running 927s on stock-weight front ends who have zero issues, but overloading them with a winch setup will crush them down every time.
Not only that, the OP just put these on in August. For a spring to drop that much in only one month isn't standard settling—that is 100% due to the extra weight pulling it down. Standard linear springs will always sag eventually anyway, but adding that much steel accelerates it instantly.
That's why I moved away from OME altogether and went with H&R springs. They are progressive and shot-peened, which gives a much superior ride quality with zero sag over time.
On the OP's rig, the primary issue is simply an overloaded front end. If you're having height issues on your own setup without extra weight, you should start a new thread with your exact details so we don't derail the OP's post.
