am i headed to a transmission rebuild?
hadtomer
Israel
Hello.
My 2006 KJ V6 has an auto trans. it has clocked 93000 kilometers..... or about 60000 miles.
when i got it last year it was stock. currently on 245/75R16. jba. etc
For the last 2000 miles i started noticing erratic transmission patterns - when i speed at the light and it shifts from 1st to second- a thud is felt from the rear diff (i mean i am in 2wd). also - when i back off the throttle and i am in 2nd gear or when i back of the throttle when it is exactly about to shift from 1st to second (like at heavy traffic) - same thud from the rear diff area. -
i have a transmission cooler.
And the rear diff has been checked and re checked again. quality lube etc.
I have no fault code appear. went to a dealer- they said its a simple software update- they updated the software and it did nothing. maybe even make things worse.
am i headed to a trans rebuild? any ideas?
rjkj2005
US
When was the last time you changed the transmission fluid and filter?
krisP
NY/PA
what shape are the rear upper control arm bushings and ball joint in ?
JasonJ
Michigan
^This.
Mine does similar to what you describe. When I slow down, there is an audible, and felt, thunk coming from the back of the Jeep, the last couple mph as I apply the brakes, as I release the brakes to accelerate, the thunk occurs again. I'm sure this is the rear upper control arm bushings and ball joint allowing the rear axle to rotate under torquing.
hadtomer
Israel
well - funny but i did not check. i have had it 4 nine or 10 months now. i will do that ASAP
Cardhu
Great White North
when you went to the dealer they may have relearned the trans. It will be clunky for a while.
Would still do checks on all the rear control arms (bad bushings) and a filter change on trans. ATF +4, nothing else.
hadtomer
Israel
Thanx- control arm bushings were replaced with lots of other stuff when i installed my tommud lift
krisP
NY/PA
anything but mopar rear upper boomerang the bushings only last about 4 months for me, similar symptoms from the axle rotating under load.
hadtomer
Israel
another 400 miles and a trans filter replacement and the problem is gone. thank you!
