i am going to install a 2.5 inch daystar lift and i wanted to know if i should get the truck realigned back to stock numbers, or do i have to get it realigned differently to compensate for the lift? thanks for any information.
You need it realigned back to OEM #'s.If your keeping the OEM upper control arms they may or may not get it back into the correct specs,then you will need JBA's UCA's.i am going to install a 2.5 inch daystar lift and i wanted to know if i should get the truck realigned back to stock numbers, or do i have to get it realigned differently to compensate for the lift? thanks for any information.
I am trying to get an apt with an alignment "specialist" this week. Hopefully he can get it right.
I called around to 10 different shops after the first alignment. I finally found a mechanic who specialized in modified suspension alignments. Not that you need to specialize in that, it was just he took his time and knew how to get it lined up. Just find someone who has been doing alignments for a while and you should have no issues.
so oem lifetime from firestone would be best
Good luck finding extended tie rod ends.You'd have to some custom machining to flip the outer tie rod ends.I think extended tie rods would be a good aftermarket item.
Has anyone ever researched it before? Some tie rod ends look like you could flip them over after you put balljoints in them from the other side. That would help some. Just thinking.....
