w8in4yurmom
Can anyone suggest a decent system that sounds decent and has some mpg improvement?
cause...
they go Wooooo WOOOO
Before my SFA swap my Kj was 5500lbs,running 265/75R16's,4.10 gears,and could get just shy of 22mpg's at 78mph(would be 14mpg's at 65mph).If stock 20mpg's on the highway is not that great but it's a Jeep so who cares,not me.who you talking to J-Thompson.
Im getting above average than others here. And the two Liby owners I spoke to.. I just hit 30K on it, and I plan to put new plugs when I do the oil, and tran fluids in a week. Also going to change the rear gear lube.
With mods I gained about 2 MPG from what it was doing. And I noticed with the forced air induction that once you get on the highway MPG jumps very quick.
No your not
Not for a stock KJ
Like I said my '03 got 15 city and 20 highway
Running a lift and 245/75 10 ply MTR's
Before that we got 17/21
My TJ with lots of mods and heavier than stock parts
Gets 13 city and 17+ highway and it only has a 3 speed
auto tied to the fuel drinking 4.0
Proper tune up
Clean oil ,ful syn
Proper tire psi
And proper driving
Take 1 out and your mpg will tank
Other than new plugs (gapped right) what else do you call a tuneup?
Just by turning lower engine rpm's does not mean better mpg's,in most cases can actually make mpg's worse.Every engine has a peak torque(HP is fictional today) and for the 3.7 it's pretty high,like 4000rpm's or something,so the closer you run the engine rpm's to peak torque the better mpg's you will get.At least you need to stay in the "powerband" which is the rpm range that the engine makes at least 90% of it's peak torque,dropping out of that range and the engine bogs down returning worse mpg's.I have found that running the 3.7 at about 2800-2900rpm's will net the best mpg's which is in the powerband,drop below 2500rpm's and your bogging the engine.I got 21 once and I think the wind was pushing me.
Low RPM is good, means the engine is turning over less. More the engine turns over the more gas you consume. If your getting 22 at 77mph.. slow down to 65 I bet you would get 25 or better.
I am thinking I could get mid 20's if I had a long enough trip to benefit from cruising at 65mph. Just my trips are like an hour or so then a bunch of city stuff then more highway for an hour or so. I drove it once for 5 hours with just cone filter mod and hit 21 with it. I drove it once 1300 miles but had some exhause leaks due to poor installation and got 19.7 average. I put in the force air mod and have came close to that one short trips so I am guesing I will be mid 20's on this long trip. But I never gotten better than 21 ever (ever).. Maybe I should put new plugs in it.
