Pins don't put holes in cast iron.
If you have any map gas, turn it on (very low) and run it around all of the vacuum lines. when the engine revs up, there's you're problem
yeah, even a blind squirrel finds an acorn once in a while
ya i saw it but how do yall not think that anythang strong enough would poke a small hole in it but ill do a video of it tomorrow and try and post it on here. will that work?
like what, a drill? a piece of straw?
typically an exhaust leak is accompanied by a rhythmic POP POP POP, not a hiss
Think about this
When you breathe in through a straw, it goes hiss.
When you fart, it goes POP POP POP. Sometimes fast, which would be the high pitched ones, sometimes just like that, sometimes just one pop.
If you hiss when you fart you have problems.
Such is the exhaust on your KJ
