3.7L making a loud his
mag03kj
LOST
My 2003 kj 2wd :( is hising when idle but when i hit the gas it stops for a quick second. Does anybody have a i deer. and i have checked the exhaust pipes.
Thanks,
MAG
I don't have any deer :rolleyes: I do have some ideas:D
have you checked vaccuum lines etc around the motor?
loose connections to anything including the air intake?
coming from engine area or?
what did you have to eat last night?
mag03kj
LOST
yes it does sound like it is coming from the engine area. and idr what ate but i have been sitting still and ppl come to the window and tell me that my tire is going flat.
You are probably hearing the air intake hiss. Open the hood and use hands to cover over the intake snorkel, and see if that is the sound. This hiss is normal as it does suck in lots of air.
mag03kj
LOST
i checked all that and its still doing it i think the driverside header has a pin hole in it. could that be it
ThunderbirdJunkie
Bronze Supporter
Newport, KY
Pins don't put holes in cast iron.
:D
If you have any map gas, turn it on (very low) and run it around all of the vacuum lines. when the engine revs up, there's you're problem
Haha, let me make sure Ive got this. Youve got a his dude under your hood making a lot noise and you cant find the deer? I bet the his got a hold of the deer! Good gosh.
Its a Vacuum leak like many others have said..
mag03kj
LOST
well i bought it used and idk what the ppl did with it b4 i got so ya i could have a small hole in the header anything can happen with everythang so...
mag03kj
LOST
not even if its a small pin hole like? but if i cant find how to stop or where its coming from ill take it to the shop
mag03kj
LOST
ya i saw it but how do yall not think that anythang strong enough would poke a small hole in it but ill do a video of it tomorrow and try and post it on here. will that work?
mag03kj
LOST
ok well i just became a member so can you help me with loading a video on there. really new to this.
ThunderbirdJunkie
Bronze Supporter
Newport, KY
like what, a drill? a piece of straw?
typically an exhaust leak is accompanied by a rhythmic POP POP POP, not a hiss
Think about this
When you breathe in through a straw, it goes hiss.
When you fart, it goes POP POP POP. Sometimes fast, which would be the high pitched ones, sometimes just like that, sometimes just one pop.
If you hiss when you fart you have problems.
Such is the exhaust on your KJ
Think about this
what a way to describe a exhaust leak.
Its more then likely not that ( an exhaust leak from what you say it sounds like but???
Just spell it out and we'll try to help you, you're not texting someone now
