I am planning to go with this size tires on a 07 gasser currently sitting at 20.5'' both front and rear. I see that some people run these and have no issues. Just to be on the safe side - is there somebody that had issues with similar setup?
Actually I just realized some liberties had factory installed 215 tires.I wonder were those fitted on the 7'' rims or were there other rims?
You will never get away with the mpg hit,even with 215/85's you will see a mpg hit and ride change as those are LT rated tires also(31 results for that tire size on tire rack are all LT rated).the much harder LT wall will result in harsher ride and decrease mpg.
I don't know about you but putting LT's on my KJ made it ride 100% better.I have a Town Car for that mushy/floaty ride.I want my Jeep to ride,well like a Jeep.True that. But 215/85 LTs weigh 16 kg as opposed to 21 kg for 245/75s. So the hit should be much smaller and more importantly ride comfort and suspension strain should remain close to factory settings.
Idk why you would want a tire size made for duallys on a KJ.. If I were in your shoes, I'd get a 245/75 in a 6 ply. Not terribly heavy, mine weren't even ten pounds heavier than the standard load sizes, maybe like 5 or 6 pound difference. But really, a KJ for gas mileage?? Don't lift it if you want half way decent MPGs.
My 04 with over 4 inches of lift, 32s, 4.10s, aftermarket bumpers, heavy skids etc still gets about the same as stock ( 21 on the highway at 75 plus, have gotten over 23 on a long trip) So while a lot of times lifts / heavier tires do hurt, if you do it right doesn't affect them that much
Oh and I run p rated tires
