window regulator I think
Discussion in 'KJ General Discussion' started by Tog, Apr 20, 2018.
  1. Tog
    Tog Full Access Member
    270
    May 9, 2016
    AU
    so my drivers window seems to have failed. I can hear the motor going but nothing happens. It made a horrible grinding noise then the window started sliding back down. Is this a likely regulator or something else?
    2004 3.7 limited
  2. daveinliberty
    daveinliberty New Member
    Apr 20, 2018
    Missouri
  3. Tog
    270
    May 9, 2016
    AU
  4. Tog
    270
    May 9, 2016
    AU
    found the kit for the other side I actually bought the pair as the left window has made horrible noises since the day I bought the jeep .
    2004 3.7 limited
  5. chanwmr
    chanwmr New Member
    Apr 24, 2015
    Upstate NY
    While you're at it, replace all of them. If one goes, chances are the others are about to go as well. For about $100, you never will have to worry about them again.
  6. Aztimer2
    Aztimer2 Full Access Member
    108
    Aug 9, 2016
    Glendale,AZ
  7. Damotee
    Damotee Full Access Member
    199
    May 29, 2016
    Cape York, Australia
    1A Auto have a great video on Youtube on changing the window regulator motor in the Jeep KJ. I did mine last weekend.
  8. Tog
    270
    May 9, 2016
    AU
    installed the drivers window kit tday will do other side when I have more time. Great kit fairly easy to install it's all steel so it won't deteriorate. the screw like cable on the oem goes into a plastic sleeve that had just cracked and broken releasing the cable. the motor works just fine why replace the whole thing with another that will do the same with age.
    2004 3.7 limited
  9. mtshasta
    mtshasta New Member
    Jun 26, 2018
    Mt Shasta, CA
    Hi Tog, where did you get the window regulator kit that has steel parts? Thanks, MtShasta
  10. dude1116
    dude1116 Full Access Member
    3,370
    May 31, 2011
    Pompton Plains, NJ
  11. Tog
    270
    May 9, 2016
    AU
    got mine on ebay
    2004 3.7 limited
  12. nbas
    nbas Full Access Member
    75
    Jul 21, 2017
    Greece
    I replaced all 4 last year with metallic ones for 72$ from ebay. The OEM are plastic and finally brake...
    Since then, I do not have any problem.
