which bilstein rear shock
Just2Bad
Ste-Sophie
I saw some saying BE5-A702-HO on lost and other BE5-6458-H7
which one should I buy ?
Both will actually work, have used them both before on different ones
the F4 BE5 6458 H7 is actually for a Wrangler with 3-5 inch lift its the 5100 series Off road racing shock
The other one is generally used though
Both need sleeves in the top to work properly
Just2Bad
Ste-Sophie
I'm a total newbie, so what do you mean by it need a sleeve ? this part is not coming with the shocks ?
Kasmir Jones
Bergen County, NJ
Mudd, I use the H7's on my set up. I checked mine and there is a sleeve in the bushing. Do I need another? I did notice that the sleeve that is there has become elongated. I also find myself having to tighten them every so often. I get a tell tale thump in the back when they are loose.
Thanks
Carmine
