What to install?
gfunkatoa
Indiana
Hey guys. While jacking up my 2002 to change the starter, I took the time to inspect a few of the front end components. It has what appears to be 2 or 2 1/2inch spacer lift. Since the stock springs are most likely sagging and both sides have wasted a arm bushings, I'm looking to remove the spacers and replace the springs and install a set of Jba upper a arms. Looking fof 3 maybe 4 inches from stock. Anyone have any recomendations or part numbers?
VAhlene
Castle Rock, CO
Well you have the right idea of getting rid of the spacer lift! I would check out the TomMudd econo lift offered by Jeepinbyal as that will net you a good 3-3.5 inches of lift above stock. Also while your on the Jeepinbyal website take a look at some of the Other lifts offered some are cheaper and some are more expensive. OME/Bilstein is what I'm running and other people have similar setups and you can achieve a 3-3.5 lift with a few tricks. I would also recomened checking out the lift FAQ. Hope that helps some!
kj04libby
Tuscumbia, AL
I've pieced a 4 inch lift kit together for $680 just bought the first part of it actually!
Stay at 3.5 -3.75 at most
over that UCA/spring contact even with JBA UCAs
PLUS 245-75-16s work just fine with 3.5 inches
gfunkatoa
Indiana
After some thought, I think I'll replace the bushings, throw in some replacement springs and let it ride. Already running 245 65 17s. That's plenty for the driving I do. Thanks for all the input.
By the time you buy stock springs and shocks you're at the cost of an Ironman lift anyways . May as well upgrade to something way better than stock junk
Snowman620
Chandler, Texas
Lift
You also might check out Rockyroad Outfitters. I am putting an order together on a lift and an ARB bumper from them. Thought I would mention.
u2slow
BC
Got upper control arms, die-grinder burrs, and no-slip locker from RRO within the past few months. No complaints. :beatdeadhorse5:
VAhlene
Castle Rock, CO
Wait till you have a problem with one of your parts and need an exchange or returned, I think that's what most people have an issue with them. They will gladly take your money but if you have a customer service issue or problem with a part is where it reaches a grey area with RRO. Hell I called em twice when I was first researching lifts and they didn't even call me back.
u2slow
BC
You can do the arms with the current lift, and do the rest later (as funds allow). Even though I had the front diff and CVs out, the a-arms are almost a standalone job.
If RRO had bad customer service in the past, I haven't seen it in my recent transactions. Being in Canada, warranty and exchanges with *any* US vendor is problematic due to freight/brokerage/tax. So I really have to weigh the cost/benefit of all foreign orders. Basically, I consider these purchases a final sale.
Luke
Interloper
Bancroft, Canada
lol .. Apathy is a Canadian trait... it does not fly south of the border. :D
gfunkatoa
Indiana
Looks like a little more research is required. I'm in no hurry so I'll keep digging. Thanks for all comments.
Luke
Interloper
Bancroft, Canada
Personally I can recommend AllJ's and JBA. I've done business with both and received help by telephone on several occasions during my install, not to mention emails a plenty. Being a customer from across the border this was very much appreciated.
I have never tried RR so I have no personal experience .. the post above was just from reading these forums for 5 yrs. :)
