Just pop the bumper off so you can see what you have, as far as the frame goes, thats all the same from 02-2012 basically
Hmmm... 13.17v vs 14.16 on a sport track install I just found. That does sound decent.
Putco 9004 / 9007 Heavy Duty Headlight Upgrade Wiring Harness - eAutoWorks
$45 sounds a bit better
And jegs has the same painless harness for $175, I guess you do pay for quality
I pulled one of my tow hooks and that looks like my only access, the lights may be mounted in the same location as the 02-04, but the bumper is different so you can't really use my previous posting dimensions. I knew there was gap between the bumper and frame but now knowing where they are and all and also knowing there is about 1/2-3/4" I am probably gonna find a spacer somewhere to place between so I don't cause any more extra wear on my bumper.You must be registered for see images
Those are the 3 mounting holes for the tow hook. All I need to know is this where I need to install.
For you guys that installed the headlight wiring harness, where did you pull power from? I know the article says to pull from the alternator but that also seems to leave the wiring in a more "exposed" way then maybe the battery or such.
