Well title says all. From what i understand it helps cv joint angle(?) and people have negative opinion about it. What is it, how is it done and why isn't it talked about much? Doesn't jba 6" kit come with it?
Cradle drop is simply dropping the engine cradle down an inch or so
Been tons of discussion about it over the last 12-14 years
Reason not talked about is because there are so many other factors to think about
It changes everything else in the front setup, CV angles may get btter but thats all.
tie rods have a steeper angle, the front driveshaft is now out of alignment and will cause vibrations, the UCAs are now at a steeper angle even with the JBA arms , and goes on from there.
Funny many people have assumed their role was to show the " oldtimers" that it would work, well after short time ost went back to the original setup or were never heard from again.
THE JBA 6 inch does come with a cradle drop but also parts to address some of the concerns that will pop up but not all since some there is no easy fix
