Circling The Drain
I foolishly decided to drive to the gym again yesterday. The reason I took a chance was that every time this has happened before it would run great for a long time, usually about 8-12 months. I got to the gym fine and just like Monday it would not start when I went to leave. Once again I got a ride home. It is still sitting there, since I have no idea what I should do next. Tow it in and have the starter replaced and hope I get lucky? The thing is, I am beginning to suspect it has something to do with the immobilizer or maybe the alarm system I had installed after it was broken into and had $2,000 worth of damage done to it. It got a new ignition and new computer crap which has always been slightly flaky.
If I knew what the problem was I would have done it long ago. The only thing that makes me feel better is that no one who has looked at it has any idea either. I could see this easily turning into a very expensive series of "fixes" that were not the actual problem until they stumble across the right one.
I would definitely be looking at the alarm system.
Tell us more about this no start.
What dash lights.
What sounds do you hear.
Does the alarm have remote start capabilities? If so does that work/not work?
What happens if you disconnect the battery for a couple of minutes?
How long are you in the gym for? AKA, how long is the jeep sitting?
Circling The Drain
What dash lights.
All of the normal ones that briefly come on when you engage the starter.
Generally, nothing at all. Once or twice (out of dozens of tries) it's like I get the teeniest beginnings of a crank. This lasts about 1/10 of a second.
No, never did.
I have not tried that.
Approximately 90 minutes.
I had it towed back in again today and had the guy come out and see it "not start". In the past, if it sat long enough it would just work. Both days this week that I got stranded I went back the next morning expecting it to work and it didn't, which is why it ended up sitting in the parking lot overnight.
DeVilliers
Maybe the Jeep just wants you to stay at the gym longer :)
Jokes aside.
I googled the Viper alarm real quick, which you have probably also done.
Have you tried to reset the alarm?
The alarm may need to be put back into 'Valet' mode, or the system will need a full reset.
DeVilliers
Further AI info
The most critical reason for a no-crank condition with a Viper 3606V is the activation of the Failsafe Starter Kill feature, which is designed to prevent car theft by physically breaking the connection to your vehicle's starter motor.
If your car will not crank at all, follow these targeted troubleshooting steps to bypass or fix the issue. [1]
1. Bypass Using Valet Mode [1]
Valet Mode temporarily disables the security functions of the alarm, allowing the vehicle to start normally if the immobilizer is stuck in an active state.
  • Turn the ignition key to the ON position.
  • Press and release the Valet button once within 10 seconds.
  • Check the LED light: The status LED should light up solid, indicating the system is now in Valet Mode.
  • Attempt to start the engine. If it cranks, your alarm system was actively locking out the starter. [1, 2]
2. Disconnect the Battery to Reset the Brain
Sometimes, the internal microprocessors in the Viper control module freeze, keeping the starter relay permanently open.
  • Loosen the negative (-) battery terminal on your car battery.
  • Remove the cable completely and leave it disconnected for 5 to 10 minutes.
  • Reattach the terminal and tighten it securely.
  • Unlock the car using your Viper remote before attempting to crank, as resetting power will often trigger the alarm immediately. [1, 2]
3. Check the Viper Fuses
The Viper 3606V brain uses external inline fuses. If the fuse powering the onboard starter relay blows, the relay cannot close to let current pass to your starter.
  • Look under the driver's side dashboard where the main Viper control module is tucked away.
  • Locate the wiring harness extending from the module.
  • Inspect the inline plastic fuse holders (usually containing a 30A or 20A fuse).
  • Replace any blown fuses with the exact same amperage rating.
4. Locate and Inspect the Starter Kill Relay [1]
If you are comfortable looking at the wiring, the installer likely cut your factory starter wire and routed it through the Viper's internal or external relay.
  • Inspect the thick bundle of wires coming out of the Viper brain.
  • Check the heavy-gauge wires (typically green and violet on standard Viper harnesses) which handle the starter circuit.
  • Look for loose connections, crimps, or electrical tape that may have unraveled. If these wires are disconnected or have a poor connection, your starter receives zero power. [1, 2, 3, 4, 5]
5. Check Your Vehicle's Neutral Safety Switch [1]
To rule out a vehicle issue rather than a Viper alarm issue, ensure your car knows it is safe to crank.
  • Verify the shifter is completely slammed into Park (P) or Neutral (N).
  • Try moving the shifter back and forth between Park and Neutral while holding the key in the crank position. [1, 2, 3, 4]
Hope this helps
rustydread777
Not so much as a do to it but more of a for it. Checked my local yard last night on line and saw a jeep dropped into the lot at the end of the day and saw... yes, a manual 4 cylinder 2 wheel drive. Devised a plan and forced myself to sleep. Woke up early and loaded the tools in the car, pitched a plan to my wife and she agreed. busted out my work and on my 3 hour lunch drove a 27 minute drive in 21 minutes, pulled the differential, loaded it in the rogue, unloaded it, and back to work.
Now I have rear disk brake and 4.10 gears in my garage to match the front 4.10 dana 30a that is sitting in my back yard. I know my major project for next month now.
Circling The Drain
Got my Jeep back yesterday. Now they claim it is the battery. I hope they are right but I have my doubts. I went with it because I was so frustrated that I was willing to try anything. I did make it home from the gym yesterday.
I mean... slightly plausible?
Alarms are known to cause higher parasitic draw, and if it keeps sensing something that pulls it out of sleep mode, it could be waking up parts of the jeep that way. since it happened twice at the gym, are people even more of ******** when it comes to rubbing and bumping people's cars? How old was the old battery?
Maybe next visit park as far away from other vehicles as possible, if possible? maybe hunt for an end spot so you can keep as much distance between your jeep and other vehicles?
That's about all I got for that idea.
Circling The Drain
The battery is 4.5 years old and it is a good model. (They are retailing for over $400 today. :oops: ) My main problem is that before I sort of retired I worked from home. The previous batter died largely because I was never driving very much or very far and it didn't get charged on the road enough. I have a decent battery charger and I will throw it on there in the winter periodically to try and offset that.
The mechanic said it was at 56% when he tested it. He threw it on the charger and it stopped charging at 82%, then within minutes dropped down to about 60%. I have no idea what equipment he used to determine those numbers.
It could be that it just went bad (or bad "enough") this week to cause the problem and the previous issues one year and two years ago were unrelated.
I will probably never know. It happened in the middle of 2024 and again in the middle of 2025, then this week. Assuming the problem was not actually the battery I may not find out until next summer. :rolleyes:
