CherokeeLiberty
My front passenger brake hose popped this morning…
D’oh!My front passenger brake hose popped this morning…
Got up and started Bert to warm up for the drive to work.(I don’t normally do that, but it was -5F) Came out a few minutes later to a grinding noise under the hood. Remembered that sound from the desert. AC clutch bearing. Endura to the rescue till a replacement arrives.
Everything is coated with road salt, even under the hood.
Cyclone prefilter on the snorkel had almost about five grams of dust and salt. Checked the Apollo filter- it’s spotless. For once research pays off.
www.saltawayproducts.com
you're gonna do 'em all, right?My front passenger brake hose popped this morning…
I think Pixel did all of the LOST decals that were sold/providedMy LOST and JBA decals from 2014 are still holding up, although the car wash and my snow scraper have made them a little dog-eared.
Not right away, but yes, they will all get done once it warms up and I have my garage in order. Of course this happens this weekend while my wife is gone and I’m planning on prettying up the bathroom as a surprise.you're gonna do 'em all, right?
if one goes, the rest aren't far behind.
mine didn't fail, but the crimps were so swollen from the corrosion/rust on them, I knew it was only a matter of time.
Hmm. A surfactant and an antioxidant in distilled water. Chemistry checks out, but “kills salt” is a bit of a reach. Would definitely wash it out.Salt-Away | Salt Removal
Salt-Away is a water-based salt removal formula of surface active agents, rust inhibitors, corrosion blockers, and other properties which eliminate the bond of salt crystals from any surface.www.saltawayproducts.com
liberal, periodic application of this before, during, and after salt events.
I ain’t doing crapola but modifying my girly pug’s wheel assist to four wheel drive. Her rear diff is out so the passenger side is freewheeling and the driverside rear shocks are blown.Todays goal , taking the day off from most everything
Taken from the drivers seat in our Toyota in Tanzania
POLE POLE , ( pronounced poley poley ) Swahili for slowly slowly
That’s always fun coming up to a stop sign. That happened to me.My front passenger brake hose popped this morning…
I did that. It wouldn’t stretch anough.could have just warmed the tube up and worked it on. then it'd be formed to the bleeder for future use.
so what is the People's preferred method of bleeding?
gravity?
pedal forced?
suction?
power bleeder @ the master?
when you do a full fluid change, do you empty the system completely, then add fresh? Before the BAN I kept MOTUL 200 and SuperBLUE in stock here (same fluid, different color) so it was easy to see when fresh was at bleeders.
