Bob, did you do a write up on your install?
Was rear diff warm when u pulled fill plug? Even though I have the riddler cover, I slam lube in there and try to get it to where a tiny bit will leak out. If it is level let some leak out, it should be just at hole line.
Have had enough of leaking trans pans from poor goop seal/ contact and switched to a PML pan and lubelocker gasket. No more leaks. Even on the diff & Riddler, 8.25 lubelocker and perfect seals.
That sensor on the passenger side trans pan has a tendency to leak. I dropped my pan and redid the rtv all because i thought it was leaking. It wasnt it was that sensor. I wrapped a rag around it and cleaned the hole pan went for a drive. When i got back i checked it the pan was dry the rag was soaked.
Guys, diff lube should be approx 1/2" below fill hole cold to allow for expansion. Yall are really putting a load on your axle seals running them that full, and that little dab wouldn't make a hoot in hell difference lubricating the actual internals.
Diff was cold, well it was around 85 here today. When I do mine I put it in until it runs out too. This seemed a bit excessive though but the fluid was clean as a whistle. I've only got about 5k on this diff fluid. Usually change it every 12-15k with the complete cover removal and good cleaning of the innards. Mines really just a mall crawler so no heavy use. I do use a gasket on the diff and no leaks.
I really checked the sensor carefully and it looks dry and clean. Got right up on it to make sure. Still clean from when I installed my Sonnax line pressure booster. Will do the RTV next time but tempted to try the Lubelocker like LibertyTC suggested. They are reusable too aren't they?
I was just letting you know ***** dropping the pan and doing all the work to still have a leak from that sensor. I was opting to use a gasket but there was a grove specially made for rtv on my 2002.
In my experience years ago now, the stamped steel pans do warp and would leak within a few months, dealer did not understand why..Just got a new pan for my last change (also with the groove like the OEM). Old one was rusting and PO had deformed that one by using a gasket and over torquing one corner. Surprisingly I couldn't get the RTV to seal so used a gasket. Had a second gasket so tried it on this new one but back to RTV next time. No drips, just wet. I'll pull the sensor next time I do the filter/fluid change and make sure. Thanks!arty52:
Only time mine'll get gloss black underneath is if I run through road construction! :gr_grin:
