What could this noise be?
first&lastKJ
Indiana
My 07 makes a noise from 45mph to 50mph. It only does it while accelerating normally through that speed. The noise sounds like mud tires on pavement. No vibrating at all. I dont know what it could be. Only have 41,000mi on it.
first&lastKJ
Indiana
Whats the best way to check the front driveshaft. I was thinking thats what it might be.
Minimike
Fort Frances, ON
I have the exact same issue, I have had it into the dealership a few times. I have 31" tires and they were out of balance by about 1/4 ouch or so. This is a good balance for larger tires. They re-balanced and the noise is still there. Nothing else was wrong with the vehicle. all vehicles have some form of drive line vibration. If it's not too loud I would live with it. My 07 is currently at 65,000 mi
first&lastKJ
Indiana
I am still on stock size tires, I tried rotating the tires that didnt change the noise. Maybe I should get them balanced.
ridenby
Gold Supporter
Kentucky
Look at the DS where it meets transfer case,if the rubber boot is ripped,or grease is visible or you can get slack in the rotation of it,by hand, that is it. Could still be bad and show none of this.
first&lastKJ
Indiana
No rips or visible grease. I checked front driveshaft no more play in it than in my wifes 02. Same with the rest of the driveline.
chill
Halfway Between The Gutter And The Stars
Be honest with you, mine makes a sound at 45 - 50 mph too. I just figure it is the Transmission trying to figure out what gear it wants to be in. Could that be the same as you? Or is it a different sound than shifting weird? I'm prolly off base with what your talking about though.
eyehatetofu
Buckeye, AZ
Wow, I have this same issue as well, but it is from 40-45 mph. I figured it had to do with my tires since I am overdue for a rotation. Now I'm kinda worried.
DocHemi
Weirton, WV (near Pittsburgh, PA)
My '03 had the same noise only at about 35mph; front prop shaft looked good and tight, no rip in boot either.
On a hunch i located a replacement CV joint (transffer case end), and replaced..VIOLA Noise gone.
By the way for those that don't know both the front and rear prop shaft CV joints are available now, and pretty cheap, so you no longer have to buy the whole driveshaft from MoPar.
Been using them for over two years now work great
