Rattle noise in gear.
eric1514
ID, USA
2005 Limited, 3.7gas, automatic transmission.
When idling in my driveway, there's a very noticeable rattle noise when I put the transmission in drive or reverse with my foot on the brake. If I shift to neutral or park, the noise goes away. It's kind of a "gravel in a coffee can" type noise or similar to a loose heat shield sound. This just started after I got new tires and performed a front diff and T/C fluid change, but those both seem unrelated.
Any ideas on where to start looking?
Edit to add:Weird. Went out just now to start it up. Temp is 41F outside where Jeep is and it does not make the noise. Maybe temp related?
Shankster
Durango, Colorado
So when you take your foot off the brake and start moving does it continue or go away?
I think I'd get an assistant to be in the driver's seat in drive with foot on the brake while you crawl around underneath with a "stethoscope" to your ear to try to narrow in on the source - by stethoscope I mean a piece of tubing or a long screwdriver or socket extension. I'd chock all 4 wheels front and rear and situate the Jeep inches in front of a very large, immovable object to avoid getting run over and make it very clear to your carefully chosen assistant not to go anywhere near reverse while you're underneath.
eric1514
ID, USA
With help, I think I've isolated the noise to the engine compartment. I'm not 100% sure yet because the noise has now disappeared. I thought the noise might be the belt tensioner, so I removed the belt and the noise disappeared. The problem is, when I put the belt back on, the noise didn't return. Even with a stethoscope I couldn't locate anything. That's confusing as is the fact that the noise was only present when the transmission was in gear.
joshcsmith13
Colorado Springs, CO
I have a similar issue that I suspect is due to a cable, wiring harness, or other item bouncing against the frame. I observed this when I was forced to change the 4WD selector cable after my original got damaged. While doing that, I attempted to secure the cable and another wiring harness that seemed to be loose and rattling against the frame and, for a while, it seemed to work. Check that out. In my case, it is/was underneath the vehicle, on the driver's side, near the firewall.
