2003 KJ w/ auto transmission, new to the 4wd aspects of it, at the moment is 100% stock.
Took it out and got into into some heavy red clay mud like you find in Tenn. I was in 4 hi and got stuck, just sat there spinning. Tried to rock it out by going forward as far as it would go , brake, reverse as far as it would go, brake, etc......
Still stuck so I put it in 4 low
Did the same rocking, but in 4 low, when I pushed in the brakes it would make a pretty serious grinding noise on the front brakes - it was pretty much exactly like I was changing gears with a manual transmission without using the clutch ?
The pedal would sort of pulse, then it was like it "caught" and slipped into gear -yes, I am still talking about the brakes - seemed really weird to me.
While I admit I no basically nothing about BLD, which is active in 4 low, from what I have read I was under the impression all it is really doing is applying pressure to the wheel that is turning - so there aren't any gears involved - still just pushing the pads against the rotors if I am not mistaken ( which I obviously must be because this was definitely gears, not a grinding noise from pads on a rotor)
I obviously have no idea what was happening and was wondering if anyone would happen to know what the heck was going on ?
I was actually kind of surprised I got stuck in the 1st place. Mud wasn't that deep and I figured I would pop right out when I 1st started rocking it. Then when the brakes started grinding like that, I must admit I got a little worried. Of course idiot that I am, I had my window down when I 1st started trying to spin out......fortunately there's not too much mud inside and it pretty much stayed on the door......so as you can see, I am obviously not that bright to begin with.
Plan was to start putting together the kj backbone/winch combo and frankenlift/OME lift after Xmas, but I obviously need to figure this out 1st. I am no expert by any means but I have changed a bunch of brake pads, master cylinders and lines, and rotors over the years on my own cars and thought I had a pretty good grasp on how the brake system worked but I can honestly say that I do not have the 1st clue to where gears become involved when dealing with brakes.....and there is no doubt in my mind that what I was feeling in the pedal and hearing was gears grinding......
Any info greatly appreciated.
