Just a note, if you have a long enough extension, you can get to the #6 plug in the way back, with out removing the coolant bottle. I was fortunate enough to be able to do so. Just be careful on the middle plug on the passenger side. If its stuck on, don't go crazy getting it off....otherwise you might accidentally snap the yellow handle clear off of your oil dip stick, like I did. Then you'd have to order another one from the dealer, and cross drill the old one out, all while not getting chunks of yellow plastic going down the tube. It was LOADS of fun, lemme tell ya.
