turn fuel off
Ozmosi
Earth
hey ,
while changing out my fuel filter realized i've got a leak in my return line under the car by the rear door behind driver seat ,is it going to bleed dry or can i shut off the fuel ?
i have pulled the number14 fuse from inside and the 2 from outside and pulled neg on battery ,please what am i missing ?
thank you
kejobe
NE Ohio
With the battery disconnected, the fuel pump will not run. But it will continue to leak until the line is empty. Once the line is empty it will stop, until you run the vehicle and the line gets filled again.
Ozmosi
Earth
What else might be why it won't stop leaking ? two fuses pulled, relay and battery disconnected.. stupid question how much is in a line because think its coming from gas tank ... leak is coming from rust spot by door behind the driver, almost have filled a bucket
kejobe
NE Ohio
Usually not that much. Could be causing a siphoning effect and that's why it keeps leaking. Replace the rusted section of line, then won't need to worry about it.
If it's the return then you can go to your local auto parts store and get however much fuel hose you need and a pack of fuel injection hose clamps (not the normal worm gear ones).
Cut the rusted section out and put the hose in place of it with the clamps.
Just make sure the hose is rated for fuel.
Jeremy-WI
Home
I don't think my Liberty has a fuel return line, a 2006 and I don't remember one when I dropped the tank the replace the fuel pump and fix the fuel fill burp
