03jeepkj
Trasmission starts in drive rather than 1st
My 03 Liberty 3.7 4x4 will sometimes start out in drive. If it is shifted into park and back it will work correctly. If does not work if shifted into neutral. It has about 90k the trans fluid is good and at the correct level. The transmission works fine other than this. Thanks for time.
I need to clairify my original post in that the Jeep will attempt move from a start in third rather than first and moving it into park fixes the issue.
