Tcc out of range
KeithKj02
Hey Guy’s!!! Got a 2002 Kj limited Check engine light went on i scanned the jeep got the code P0740. The thing is a day earlier the coolant hose blew out and emptied the antifreeze on the engine . I don’t know if this affected the torque clutch converter or not ? And I couldn’t find its location on the engine.
Thank you !!!
P0740 is the power train control module ( PCM ) has detected something unusual within the torque convertor clutch circuit
So yes if the hose busting and spraying HOAT coolant everywhere more than likely caused this
Need to spray down everything, get it clean and dry first thing
Also best to remove each coil pack & use compressed air to remove the coolant out from each spark plug cavity if present.
