African Child
So I orderd a set of strut spacers from the States, and installed it yesterday. Problem I am having now is that the ball joint on the upper control arm are touching the coil spring as the suspension drop down. If you jack up the front end you can see the ball joint pushing against the coil spring. Except for a loud bad noise it also damages the rubber on the ball joint. Normaly the grinder would be the first thing in my hands but in this case there is nothing you can cut away.
Need your help here in sunny South Africa please?
