Stock Jack not Tall Enough
LiberatorBB
Seattle, WA
I recently Frankenlifted my KJ and put on 245-75-16s and my stock jack no longer lifts the front tires off the ground. Anybody know of a jack I can buy that's a bottle jack, tall enough, and has the U shape at the top? Thanks
CactusJacked
Chicago Suburbs
Carry a couple of short 2x6's with you to set the jack upon. If you have a manual trans, those blocks could also come in handy to use as a wheel chock should your parking brake stop working.
Luke
Interloper
Bancroft, Canada
I bought a bottle jack as well. Like Cactus, I still need to carry a couple 2x6 scraps screwed together.
eyehatetofu
Buckeye, AZ
I use a 12 inch hunk of 4x4 with the stock jack. Fits under the front seat when not in use. I only use that for road side issues. I have a floor jack for home use.
CactusJacked
Chicago Suburbs
Now I gotta go test my jack and see if it still reaches. Hope I don't jinx myself, but in all my 38 years of driving, I have never had a flat tire. No sh.... kidding!! ;)
Stock jack works , just have to know where to use it.
Here is an example since this comment comes up all of the time from people who just lift
with 32 inch tires rear lower control arm bracket on the rear diff is about 11.5-11.75 inches, stock jack goes up past 18 inches , now to me that is plenty to lift a KJ off the ground to change a tire
LiberatorBB
Seattle, WA
It works for the rear, it just can't lift the front from the jack point in the instructions on the jack. Where should I lift it at for the front wheels?
Under the control arm
works until you install 40s then you'll need another jack
Works buddy of mine got his lift parts in one weekend I was out of town, couldn't sit there and wait for me and use of the garage so he even installed his lift in a gravel driveway with the stock jack. Just have to think outside of the box at times
Luke
Interloper
Bancroft, Canada
I just use the standard (notched) lift point for the front. Actually I lift just behind the notch and put my jack stands in the notch.
You just need a solid block of wood under your jack... to give you a boost.
Caveat : Always block your wheels!
LiberatorBB
Seattle, WA
Ah that works! Glad I don't need a new jack or modifications. Thanks
