Replacing CV and Intermediate Shaft
CherokeeLiberty
Northern MN
I am planning on replacing these next weekend, and I want to be sure I have all the correct parts. Besides the two shafts, are there other small parts I need to get? Any seals? There’s gear oil leaking from the housing, and I’m not sure if that will be solved by a new CV and shaft alone.
duderz7
Weiser, ID
If you're leaking is go ahead and pick up a seal and bearing as well, there are right ups on this site about the process.
CherokeeLiberty
Northern MN
Thanks.
Is there a bearing there, too? Once I tear into this, I won’t be able to go anywhere until it’s back together, so I want to be sure to have everything I could possibly need.
