Renegade roof light output
forcefed44
North NJ and Eastern shore VA
I have contemplated replacing the factory light globes with LEDs but wanted to know before I attempted that, is there any way to upgrade the lighting output? I already swapped the halogen bulbs to Samsung LED 9006s 50w (expensive way to just test) and they are brighter but not super bright.
Relays, Wiring? where to go from here..
JasonJ
Michigan
Are the reflectors in those lights even worth the hassle? Seriously, I don't know. Some OE aux lights have really poor reflectors; you can get more output from LED's swapped in, but if the issue is light dispersion or projection out onto the road... that's all the reflectors job and there may be no good way to improve on that.
dude1116
Pompton Plains, NJ
I always thought that halogen lights in that bar were fairly decent. Buddy of mine had one and I was fairly impressed with the light output. Throws far and wide.
I retrofitted Rigid Dually's(using JK foglight kits) in my Renny lightbar using 4 Dually 10 degree spot lights,10 times the light output from the halogen bulbs(had upgraded silverstars in stock housings).
Was going to try HID's with the slim ballasts but there was no room to fit the ballasts under the cover with the stock halogen housings.
Only pic I have of them...........
jeeplib05
Ohio
Why not just extend all of the wires from the ballast and put them in the engine bay?
That'd be easy enough and you'd get tons of light from them.. run all wiring through the stock holes and you'd never know it was done
CzarKJ
Townsend, MA
Got fog lights? Legal way to add 2 extra lights and fine to use all the time (in my state laws may be different elsewhere).
forcefed44
LED bulbs in.. and it's brighter but not that much.. More like an accent lighting look when projecting on the road.
TJKJ: I hear you on the retrofit. I was thinking about going round LED spots and fabricating the mounting brackets and shell incorporating the factory adjustments for the globes. I want to keep it as close to stock appearance as possibly.. Kind of my theme.
jeeplib05
Ohio
You would've been better off getting high wattage halogens than LED bulbs.. going from the stock 35w or whatever to 55w wouldn't do much at all
LEDs are only bright when they're in an LED reflector, so putting them in a halogen one makes a very short range of light without spread
I would go through the effort of installing HIDs, but that's just me
You wouldn't change ANYTHING about the housing, lenses, etc when you'd just be putting in a bulb like any other
You'll get much more light output from those than small LED pods
Have you seen the output of Rigid Dually's?
I'll have to find a close spot to take pics of the lights at night without the cops getting on my a$$ about it,people are so touching these days when you turn night into day.
jeeplib05
Ohio
I'm sure they are bright, but the OP said he wants his lightbar to look stock so putting pods in isn't an option
MTKross
Florida
Was about to ask you that. I've used pods in the past on other builds but all mine seem to have been great at throwing a ton of light up close but failed at projecting it far down the road. Are the Rigids good with throw?
I've never had experience with the stock lightbar so don't have much knowledge on how much that put out in the first place
If you get the 10 degree spots or the 8 degree hyper spots they project pretty far,twice as far or more then the stock Renny lightbar with 55w halogen bulbs.
