Rear window will not open from handle
Discussion in 'KJ General Discussion' started by toonman4, Apr 26, 2011.
  1. toonman4
    toonman4 New Member
    21
    Mar 7, 2008
    McHenry Co. IL.
    On my 07 liberty the Rear window will not open when using the rear door handle
    It works fine from the remote
    I took off the panel on the rear gate and all the wiring seems fine and i can hear the microswitch click when I pull on the handle but it does not release the latch to open the glass
    Anyone have a similar problem or know what needs fixing?
  2. Billwill
    Billwill Full Access Member
    1,500
    142
    Nov 26, 2009
    White River, South Africa
    The microswitch may "click" but not actualy work. The microswitch sends ground to one of the inputs on the BCM so either the switch is faulty...try shorting it out....or you have a bad connection somewhere from the switch all the way to the BCM!:freak3:
  3. Dmut
    Dmut Full Access Member
    118
    May 22, 2009
    one of xUSSR republics
    common problem - microswitch got rusty. clean it or replace it.
  4. JeepKj03
    JeepKj03 Full Access Member
    96
    Dec 18, 2009
    Oakland, MI
