Rear suspension or axle clunk when getting on or off the gas.
atikovi
Suburban Washington DC
New to me 2006 6-speed with 180,000 miles. Whenever I even lightly step on the accelerator or take my foot off it, I hear and feel a clunk from the back like some suspension bushing is loose, worn or missing. Even parked in the driveway I can look out the door when letting out the clutch and actually see the axle moving slightly when it clunks.
Right now I have the rear up on jack stands at the frame so the axle is free to hang down. I tried using a pry bar to move things around and hopefully see what's loose, but got nothing obvious. I know these models had a recall for lower control arms, but the recall is not open on this truck so it was probably already done. The upper control arm looks pretty clean but don't know if it was replaced 1 year ago or or 5, or if it's a cheap low quality part.
Two unusual things I noticed. With axle hanging, I can move the coil spring around. And I can lift the axle up by hand almost an inch with no resistance. Is the shock bad? What else to check?
u2slow
BC
Upper arm bushings. They tear. Best viewed when not jacked up.
It is very difficult to remove the OEM bushings without stretching the holes (then new bushings won't stay in place.) As careful as I was, still had to tack-weld the new Moog ones in. They didn't last long either, so I swapped over to another used arm.
duderz7
Weiser, ID
Jack it up by the axle so it's closer to ride height during inspection. The bushings mentioned would be a good place to start, next the ball joint on top of the diff, check for play front to back. Also loose shock hardware or bad bushings there. Lower arms, and I joints at the drive shaft. Any of the could be clunking. I don't suggest trying to replace bushings or ball joints in the original arm either as mentioned before. Axle movement is not necessarily bad, keep in mind it's only rubber holding it in place. Oh and the loose spring at full extension just means you need new springs and shocks because they're worn out.
The arms are made of tinfoil, however if you spilt the old bush outer sleeve with a hacksaw you can knock them out without wrecking the arm.
u2slow
BC
And they come two in a box? I don't know if the control arm is OEM and if the aftermarket bushings will fit aftermarket arms.
Each. One per box. I will never buy them again.
I got a whole arm from rockauto for $74. Amazon wasn't far off that price either.
atikovi
Each. One per box.
That's odd. At the Moog site it says 2 in a box, https://www.moog-suspension-parts.com/moog-k200428 and $13 at Rock.
Question:Does part number moog-k200428 come in pairs or singles? Answer:part number Moog-k200428 comes with a quantity of 2 bushings per box.
Question:K200428-Control Arm Bushings- Could you please let me know, does the following part come with 2 bushings in the kit or 1. In other words do i need to buy 2 x kit of 1 x kit. product id: moog-k200428 rear upper control arm bushing - at frame Answer:Moog-K200428 comes as a pair of bushings per kit.The information I have show you will only need one kit for your vehicle.
u2slow
BC
My invoice from 2016 says I ordered 2 units. Don't recall having any extras.
Good luck
atikovi
Problem found and fixed. I had the truck up on jack stands and pry barring every suspension part I could reach but didn't see any play. Even jacked up the rear end to ride height and still nothing. Lowered it to the ground and rocking a tire a little, made the clunking sound. Crawled underneath and moved the tire with one foot to pinpoint where the noise was coming from. The right upper control arm bolt was totally loose. Torqued it down and the noise is gone. Will take it for test drive tomorrow. Still want to replace the shocks. Suggestions? Preferably from Rock Auto and preferably not from China.
seafish
I prefer the overall manufacturing and ride quality of Bilsteins or KYB on all my vehicles (Jeep, Toyota and Dodge Ram) and am willing to spend the cake to get them over Monroe or Rancho …
That said, ANY new shock will be a definite improvement over old worn shocks.
