duderz7
Let us know how they come together
Inline Tube has some good stuff. I have a whole set for a project in the garage. Won't get to try them until the body comes off the frame though...
Same issue with Advanced/Carquest, also Sunsong brand. Seems to be manufactured incorrectly. Can I flip the banjo block and the ports for the fluid still work?
Are you sure you have it turned the right way, makes a huge difference
Finally got it all done after taking a break to do some house projects.
Bled the system, drivers front caliper bleed valve is rounded off.
I will try with my vice grips tomorrow, worst case, new caliper.
This was a pain in the rear to replace all of this.
For posterity, avoid Sunsong (NAPA and Advanced/Carquest) soft lines, they do not fit correctly. I got mine to work with some tedious, but safe modifications. I recommend Raybestos.
