Hi,
I have a 2003 Jeep Liberty limited Ed. 3.7L V6 with both electric and mechanical cooling fans.
I was on my honeymoon when the radiator needed to be replaced. The guys at the shop found that the electric fan was missing a pin from a while ago and the e-motor shaft made the fan's mating hole larger so the shaft just spins and the fan doesn't. It wasn't replaced as the town (Payson) didn't have a replacement part.
My questions are:
1. Do I go OEM on this part or an aftermarket would do? (Correct me if I'm wrong, this is usually for KJ's with tow package right? There's a receiver at the back. Sorry it's my wife's car so I don't know much about it.)
2. I can't find a solid answer, but I think I should be able to replace just the fan on the shroud. Am I correct?
3. If aftermarket, any recommendation?
4. Is it possible to remove the shroud where the e-fan is attached too easily without removing any hoses?
Thanks.
My questions are:
Thanks.
