spideyrdr
Hi all,
I have been lurking here for a couple of days and learned a boatload. My '05 KJ has been just waiting for some upgrades, and I decided to go with a Powertrax No-Slip in the rear. In the literature there was an addendum stating that it "may contain" 2 slotted spacers and 2 slotted drivers. Indeed, this is what I received.
The instructions specifically refer to there being only 1 slotted set - so this was a little bit of a curve ball, and a key item they could have mentioned would be if the "slots" would be facing the same way ("out" at the same time, for example) or be 180 degrees off. I THINK there is only 1 way it could be assembled because of the integral pins, but I was just curious if anyone else has done an install of the 2 slotted setup and which way the slots lined up. Mine are facing the same way. It started raining and lightning here tonight during my install, so I got 95% done and will finish tomorrow, but just wanted a buddy check on this, if you will. I also left a message with Richmond to see if they call me back with their input.
Thanks in advance for the input, I hope to become an active member of this kick-ass Liberty community!
Cheers,
Jamie
'05 Liberty rolling on 245/75's, 2.5" spacer lift, ARB Front w/ OEM skids underneath - Skink Super Sliders (coming soon)
Cheers,
Jamie
