on going front end battle!
NJallDAY
New Jersey
So i changed my passenger hub bearing on sat. It started off making noise only while turning left and progressed to a constant noise. Once it was changed the hub was silent, until today.... every once in a while while turning left i can here the hub. The odds of me purchasing a bad hub seem prettly slim. So is there any other reason to cause a hub to go bad? Or maybe the noise is coming from something else? At my witts end on this one so i need some help. Thanks, NJ
4x4kayak2112
tx
If yours is 4wd id say check your front cv joint, mine on my old car did that.
Sent from my Home Phone using Tapatalk 2
yellocoyote
Check the passenger side CV where it meets with the intermediate shaft.
X2
Also could be the intermediate shaft itself. Replaced mine last week along with a remanned CV from NAPA. The splines on the end of the shaft were in bad shape - pretty rusted and worn.
NJallDAY
New Jersey
Im pretty sure its the cv. The lbj boot is torn too so i might as well do it all at once
