Ome 947 or 948
05KJBaj
Hey guys, tomorrow I am going to junkyard to pickup some spring, I found some ome 927 for the front but cannot find the 948, I only found 947. What is the difference between the two? Is 927/947 a good setup ? Are the 947 a different size than 948 ? I do not tow, only dune "high speed" offroad
947s are more like stock rating, but give lift
They are same size as 948s
05KJBaj
Thanks That's good ! Do you think i would need the 948 in my case for offroading (jumps and bumps) ?
Good luck
after installing you may need to add an extra isolator in the rear to level it out depending on how the front settles in after alignment etc.
05KJBaj
Good luck
Back from the junkyard, I took the front 927 with ome strut and the 947 coil springs for the rear. Unfortunately did not find shocks for the rear, is it okay to run the taller springs with the stock shock for now? If not I want to put some tj fox 2.0, good idea or not?
05KJBaj
said tj for fox but not sure what fits actually
05KJBaj
L
Have to know model, size , mounting points etc
Little update, I finally got everything mounted, I bought some fox 2.0 for the back, they were around 4 inches longer than the stock shocks when uncompressed. I bought them used from a small suspension shop for 120$ the pair, he told me they were for gmc trucks and grand cherokees, they seemed a little rough but I thought it would make up for the softer 947 springs.
Everything is mounted and looking good, car drives great, i jumped it right after coming back from the suspension shop lool, there is a road ending on a gravel road and before it is gravel it goes down so I went flying from the road to the gravel, big difference in comparison to the stock shocks, I liked the way the fox worked too.
Total money paid is 250$ including all the parts and labour, totally worth it imo.
Didn't have the chance to actually offroad it yet. Here is some pics, i'll take more once it is aligned there is still some negative camber in the front
05KJBaj
L
Went on a quick dune drive for 20min and I am really impressed and really feel a big difference in comparison to the stock setup. I was always "bottoming out" on the shocks and was always at full compression when jumping or hitting bumps, now it really absorbs very well.
Really happy of the way the fox shocks turned out too
05KJBaj
Here are some more pics
