Newbie spring/shock install questions... (DONE!)
So, technically my second post, and I'm digging right in! Looks to be a great, knowledgeable crowd! Now that I've buttered everyone up, I have a few clarification Q's. I read the FAQ's, did the usual searches and it seems there is a very good amount of conflicting info regarding install, what is needed, what isn't etc. I am asking to clarify a couple of these things... I am doing the OME 926/948 springs with the OME nitrocharger sport shocks.
http://www.arbusa.com/uploads/pdf/newproductadvice/nitrochargersport.pdf
I am also adding an above mount leveling spacer as well to level the truck (unless otherwise advised) So my quick questions:
Front:
1: UBJ- some say this lift can install without removing, some say remove. Yeah or nay?
2: Tie rod, same as above.
3: Front Sway bar, remove?
The rest seems pretty straight forward wrenching.
Rear:
1: Seems the best route from looking at the whole thing is, jack up rear of truck, support with jack stands, remove rear wheels, support center of rear axle with floor jack, remove shocks, lower rear axle until low enough to remove springs, remove said springs, install new springs, raise rear axle with floor jack, install shocks, wheels etc.
Am I missing anything in this process? Seems pretty straight forward, but I am looking for any tips/tricks that I may not be seeing/miss.
2: rear sway bar... remove for all of the above, or not? If removed, consequences of leaving it off VS keeping it on. I have no reason to leave it, if safety and load capacity are not hurt in any way.
I still haven't received all the parts, I am doing a full new install with new iso's etc. Stock UCA's seem tight, though if I get in there and need new ones, I will do what I need to. I have not measured mine yet, but I will, and post both before and after pics as well as measurements. Hopefully everything arrives this week and I can dig in this weekend. Thanks for the help and look forward to lot's of discussion.
Front:
Rear:
