Need Help Figuring out the name of broken part
rbobrowski
Michigan
I hope that someone can help me figure this out, so the other day I ended up getting in to an accident and the end result was me hitting a big rock. Anyway the part that I broke I can not figure out what it is, the part is under the passenger side axle shaft tube, from what I can tell it helps to hold the axle shaft up. It's a L shaped aluminum casting with a cut out where the axle goes, it also has 2 rubber bushings where it bolts on to the car. I don't know if this is a good enough explanation or not but if someone could please help me out in anyway I would greatly appreciate it and I will try to get pictures of it as soon as possible. Thank you guys for your time.
belvedere
SD
So this is on the front end? Pics would be great.
rbobrowski
Michigan
Yeah passenger side right below cv axle, it supports the whole passenger side axle shaft. I'm not positive that axle shaft is the correct name but hopefully it can give you an idea. I'll try to get pictures up in a couple minutes.
belvedere
SD
Lower control arm, maybe? (just a guess, without seeing a pic)
rbobrowski
Michigan
I added photos of the part that I am trying to identitfy to the original post sorry for the delay. I know they are not the greatest photos but hopefully someone might be able to figure out what it is. I'll try to get better photos in the morning. Thank you everyone.
Gyro
Nova Scotia
ouroboros
Montrose, MI
That is the center carrier mount.
His broken part is the passenger side crossmember P# 52059465ae(supersedes ad)
FRONT MOUNT BRKT for 2003 Jeep Liberty|52059465AE
The part he needs is, $520 :gr_grin:
Gyro
JEEEEEEEEEEEZ talk about just emptying every pocket!!! :thumbsdown:
Gyro
Wow, I guess he needs to break cheaper stuff. I'm with ouroboros, head to the pick and pull.
TwoBobsKJ
Northern Ohio
time to search parts yards, eh?
That'd be my course of action!
Sent from my iPad using Tapatalk
I agree - but I wouldn't buy just that part. You can buy the entire front diff for less than $200 - and there are plenty out there. Nearly all the KJ's I see at pick-n-pulls have their interior guts torn out - the front diffs are always part of the carcass that is left at the end.
