Any after market Trailer Hitch Installed?
What
year/model is your KJ?
Do you have the wiring diagrams? You can download the KJ Service manual here...except 2004 model in which case use 2003 manuals....these include wiring diagrams.
Fuse 34 in the PDC box under the Hood I presume....feeds a lot of modules/solenoids etc.
which you may have to physically disconnect the connectors thereof or cut wires to isolate the drain...wires can be soldered together with shrink tubing later.
Once you and I have the same wiring diagrams in front of us we can go through the process of isolating the drain!
Download manuals here:
www.colorado4wheel.com/manuals/Jeep/KJ
Yes but I built the trailer harness myself and have it running on its own fused circuit with relay. I have all the wiring diagrams as well, iirc you're the one that sent me the pdf of the 03 manual when I was having intermittent charging issues when I first got my Kj.
Anyways, I'm about 90% sure I've narrowed it down to the rear cargo light. All my interior lights are led and I have a toggle switch wired in so i can turn off the residual glow, but if the rear cargo light is manually turned on it throws everything out of wack. That's when it hit me, I was messing with my amps the other night and the lights timed out so I tapped the rear cargo light to see. Apparently the light is "on" but remains unlit in the bcm's eyes. So I either remove my toggle that keeps them from glowing, or never manually turn on the cargo light.
Question: What's the best way to wire in a single toggle switch to both evic map lights and rear cargo light? Anything other than how I have it now only turns off the front or rear separately. My led's are extremely bright, and keeping a halogen bulb inline doesn't cut it. I tried resistors, but my leds were half as bright as they are without them. Can't go back to stock as I modded the evic and rear cargo light for the led.
Example of how bright my interior lights are.
With camera set as dark as possible.
Sent from my SM-G920T using Tapatalk
