lower radiator hose?
Nooby
VA
moparman
Baltimore, MD
My new lower hose did not have a spring, so you might have to pull the spring out of the old one. If you forget, I am not so sure it matters.
If you are changing your hoses because you think one is leaking, start looking at your radiator. Mine started dripping off the end of the lower hose and made me think it was a bad clamp or hose. It wasn't.
Nooby
VA
yeah, i was looking at the gates hose, and it say's
"GATES Part # 22718 More Info Molded Coolant Hose; 1 25/32" x 12 1/32" Does Not Contain Spring"
the other hose's listed mention nothing about a spring
no leak, just some PM, the hose has a green color too it, and since I will be changing the high and low pressure power steering lines due to a leak on the high pressure, it would be a good time to do the radiator hoses too,
moparman
Baltimore, MD
Not a bad idea for sure. Seeing the other Chrysler cars in your signature line - you are not a "noob". :)
Nooby
VA
my dad worked at the factory in Delaware so kind of influenced my buying decisions
Nooby
VA
I called the dealer, and for 2.50 more for lower and upper rad hose I can get it from them, and they said it has the spring coil in it
so i will pick it up there
thanks again for your help
Nooby
VA
I picked up both upper and lower hoses from the dealer, the lower did have a new spring coil in it, I got it from an online dealer,
cost was 28$ total including shipping
here is a pic of new vs old hoses
upper hose
lower hose
