Loud thud sound from suspension
mindbomb
California
Sometimes, when I turn steering wheel left I hear a very loud thud from the front left suspension. Also happened when I climbed a (really) low curbside, pretty slowly :Violin:
Everything else behaves normally. Visual inspection shows nothing (well, to me).
What might that be? How to check it?
I have a 1000 mile journey coming soon with the KJ I don't want to have any issues during this long drive.
Any input appreciated. Thanks!
Check the sway bar bushings and end links. Can replace all of them in an hour and with $50 so that might be worth a shot if they are suspect.
Could be the driver's side steering rack bushing as well. You can get some rubber washers and jam those above and below it. 2 1/4" x 3/4" x 1/8". I did one below and 3 above, better to do 2 and 2 but I could only get one under it.
mindbomb
California
Thanks! What's the process like?
Also - is that a critical fix or can be delayed to +1000mile drive later?
Sway bar stuff is just unbolting and replacing stuff. Usually not a bad job. Steering rack bandaid is a little tougher, not by much.
Safe to drive I would think, annoying yes but especially if it's sway bar related it's nothing that'll strand you
