Lift kit install turmoil
Austerity
Evans, Georgia
Well I was installing my 927/948 OME today and everything went generally smoothly, except for one of the front struts I asked my wife to put the nut on the top while I compressed the spring a bit. She cross threaded the nut and destroyed the strut. Gotta love mot having any real help. Well while I wait on a new strut I will have to buy is there any way I can run the factory strut for a few days? I don't want to have to rent a car on top of this. Thanks
Sent from my Galaxy Nexus using Tapatalk 2
You could, may handle a little funky since you will have one new and one well worn shock on there
Should be alright for a few days
Austerity
Evans, Georgia
Ok thanks. Didn't know if the lengths were different.
Would have been so much easier if a local shop would have assembled them for me but nobody would.
Austerity
Evans, Georgia
Well, I got the 927 compressed down enough to get the nut on the strut, but there's absolutely no possible way to get the spring compressor out. Fml... I want to scream at my wife so bad right now.
spideyrdr
Centennial, CO
Don't fret, my wife didn't help at all other than making sure she could call 911 if the Jeep fell on me or something. A new strut probably costs a lot less than a divorce ;)
I fought to get the compressor out the the one "tower" I did myself. I used 790 springs too, which might even be fatter, not sure. Turns out just disassembling the compressor was enough to let me pry out the compressor 'fingers'.
Austerity
Evans, Georgia
As usual my posts were deleted on here (happens constantly on this forum).
I posted a reply saying it was the rear upper control arm bolt towards the rear of the vehicle that was loose. Problem solved, must have always been loose!
Thanks
05renny
ohio
Go easy on your wife man, it's not her fault you don't have anyone to help your project.
Austerity
Evans, Georgia
Really wasn't trying to blame it on her I was just frustrated. Had people that could have helped but wasn't the right weekend I guess because everyone was busy.
I got the new shock in and got it aligned (with no help again) and all is good!
