Do you want a 1.5" lift or a 3.5" lift? Looks like the tommudd can handle a lot more weight up front, too.
I would imagine that tommudd would think so. :bowroflwerd6:
(When I can afford it, that's what I'm likely to get.)
Doesn't matter to me, both are good kits overall
One thing the OP is missing is the fact that with the OME he will get 2.5 inches of lift, with the TM Econo will be 3.75 so depends on how high you want to go.
The OME can be made to get that height but of course you'll need clevis / top plate in front and 4 extra isolators in the rear
Think it over
Hard to say really, a lot depends on your driving habits and where you drive. 50,000 on a smooth Interstate Highway is much different than dirt / gravel roads with lots of potholes.Ok thank you Tom. One more question which one do you think would last longer?
All said and done my first OME lift lasted way past what stock springs would have. I removed it with 100,000 miles on of course it had sagged some
I expect the Ironman should last with similar results which the TM Econo uses in front
yes get the terraflex bumpstops, you need them. Get the rear bumpstops JBA offers also, unless you do the hockey puck method. If you are going with the full kit- front and rear; check JBA's pricing, it was cheaper for me to buy the TM front kit, then the JBA 4" rear coils, rear shocks, and y link extension, rather than the complete front/ rear kit. I highly recommend getting the A arms as well. They are the best, real ball joints. And do the lower ball joints too, with real Moogs.
Clevis spacers- go ahead and get the .50 ones. I did the 3/8 ones and was not happy, not enough lift. If you don't like them and it is too high, I will be happy to mail you my 2 weeks used 3/8" ones, for nothing. That quarter inch difference equates to a half inch of fender height. Why? I don't know, Tom was right though.
If you do the lower ball joints, you will be pulling the CVs. If you do, I highly recommend replacing the axle seals with only Mopar seals, about $21 each. Don't use another brand. See my other post string about axle seals and doing them 3 times......
Just think about "what can I replace since I am already tearing things apart". If it is a low price part, just replace it now. And presoak all of your bolts/ nuts. Get a 15, 18, 21mm sockets and wrenches. You will use those for this job.
Check your rear spring upper snubbers, (upper bumpstops) Mine looked and had the strength of mud dobber nests. Dry rot. Get new ones from 4wdparts.com
You will need to extend your rear brake lines. Do so with lowering brackets which is a how to on this site.
I love the ride of my TM Econo kit. No comparison with what I had, rides awesome, and everything is tight, like a brand new vehicle.
Yeah, I don't know if it is an oversight by JBA, or what, but it is cheaper separately.
No issues at all. over 4 inches would be of concern. I'm probably 3.25 over stock. I'd be more concernedwith factory lower ball joints. They were junk.
Check the ball joints and see if they need replaced or not. I always check them on the lifts I do, very seldom are they needed
