Lift faq: Read before asking questions!
Fogtripper
Hi folks,
Did the spring/shock upgrade (OME and Bilstein) and the liberty steering is rather squirrely after a second alignment. The shop said that the control arms are at too steep an angle now because of so much lift (likely only about 1" above stock height) and there is no setting that would alleviate the "wandering". My wife drove it home from the shop and she mentioned that it now pulls a bit to the right (was not doing so pre 2nd alignment). Attached are the alignment readings.
Edit: Does anyone have a readout of a "properly" aligned KJ with lift that tracks straight and no issues with tire wear?
The shop may not know what they’re doing with lifted Liberties…
I’m at 3.5 inches of lift and this is where I am at (a couple of alignments ago as I can’t find the most recent one): (note, I have JBA upper control arms because my Liberty has over 2.5 inches of lift)
A little caster has to be sacrificed to bring camber and toe into spec. But at 1 inch of lift it should be a non-issue. Can you measure center of the wheel to bottom of the fender flare for us to verify your lift height? Stock on a KJ is 19”.
Having the camber or toe out can 100% make it drive squirrelly. But structurally rusty control arms (especially rear ones) or rotted out bushings can make it unstable too. There was a recall on KJ rear control arms a while ago for rust damage which you can check on and possibly get free replacements.
Fogtripper
It's a 2002 (if that makes any difference) with stock control arms.
Will get the measurement of height when I get home this eve.
Looks like that recall was 2004-2007 libertys.
Just added to my response while you were typing. Hit refresh… added info on rear control arm recall
Fogtripper
I know she had a recall done that added the protective piece with the trailer hitch to guard the gas tank. Will have to check if they did the CAs back there.
Fogtripper
Just an update: IIRC the height measured ~22", so I decided to just go ahead and get the JBA arms which will (HOPEFULLY) be installed this weekend. Gotta pick up a couple spare wrench extensions just to be safe for the driver side.
Jacked the front up and put on stands, removed the wheels and the arm contacts the coil on the driver side so the JBAs were a good purchase just for that.
mcnaughb
With the OME lift and spacers, I am at 21.75. I have JBA front arms and iron rock offroad rear lower and upper adjustable control arms. I have what feels like driveline shudder/imbalance between 35-50 MPH (under load only). My transfer case and diff angles were within a degree when setting up the upper control arm. Has anyone had to go to a different drive shaft after a < 3inch lift?
Thanks.
They are not needed, at least with my KK. My extended rubber bump stops from above miss the grease zerk on the JBA UCA ball joints. I hit a huge pot hole at speed last winter and bottomed the front out. No issues.
NewKJMudder
So my rear spring is popping out. I have a 2.5" lift. The springs are skyjacker and the shocks are rough country. I'll post pics. The bottom of the spring is bolted down. What can I do to fix this problem?
Thank you.
I'd guess the shocks are too long, that's all there is to limit downward travel on the axle. They look like they would be better on a bigger lift.
You also desperately need new rear bump stops!!
NewKJMudder
Yes I ordered the shorter travel shocks and bump stops this morning.
NewKJMudder
I ordered these they are called Spring Isolator -- Front Upper Or Front Lower.
Is this the same as a bump stop or is there something better?
So I ordered this set here , where do I put the half round pieces is it 1 for each rear wheel?
The half round ones are for the front, they clip in above the upper arm, the rears go inside the spring and clip into the round metal bit at the top.
