Liberty '14 Leaving Puddles on Driver's Side
infinitempg
Bradenton, FL
We have a 2014 Jeep Liberty and a couple times in the last week or two we've had water vapor coming from the AC vents. Changing from recirculating to outside doesn't change it. Been humid here but always humid here and has never done this before. Had a dealer check the AC and they said everything is good. No moisture or leakage inside the car. But we've noticed something just start around the same time this did.
When we park the Liberty in the garage we've started noticing a large puddle of water under the rear door driver's side, just in front of the driver's side rear tire. So much water that even a day later there's still a good sized puddle. Looked under there and didn't see any drain line or anything that might be causing this.
Not sure if these two things are related but they both seemed to start up around the same time. Any suggestions?
First what year do you have again?
2004 or ??
Libertys were only built from 2002-2012
2002-2007 were the KJs and 2008-2012 the KKs
Now on to your problem, there is nothing in that area that would be draining
nearest thing would be the AC vent hose on the firewall on the passenger side
How big of a puddle is it?
Do you have to drive very far for it to show up?
Is there any smell from the " vapor " when it comes out.
Wonder if heater core going bad/ leaking or ??
infinitempg
Bradenton, FL
My mistake, it's a 2012. Tracked the puddle sooner after it happened and turns out it's coming from around the front of the driver side compartment, firewall area. Seems we have a low spot in the concrete floor and the water puddles where I described before. I think it was smoke and mirrors making it "appear" to be back there. Think it's just AC moisture from our massively humid air.
JasonJ
Michigan
It sounds like the AC drain, and it's just running along the frame or body of the vehicle before dropping to the ground... I'm not sure I'd worry about it.
